BlackHole Gurus
I have had a problem ever since I bought a Vu+ Duo, and now Ultimo. This problem is not specific to BlackHole but to any image I try. I post here because BlackHole is my favourite image and I have no reason to change.
The "problem" is actually more of a major inconvenience rather than anything else as there IS a work-around.
Let me explain: My display is a commercial plasma panel. This has 2 connections that accept Component In only and 2 connections that accept either Component In or RGB. One of the Component only inputs has Audio In to feed the onboard speakers and so this is the input that I use day to day.
The problem is that when an image is first flashed to the receiver, the Component only input of the screen is not capable of displaying the default Vu+ output until the Vu+ is configured for Component output. But I cannot see what is supposed to being displayed to change it! The work around is to unplug the Vu+ from the Component input and plug it into the Component/RGB input. When this input is configured to RGB then an image is displayed on the screen (albeit shrunk and green) so I am able to navigate to AV settings and change Vu+ output to Component and then plug it back into the Component only input.
With me so far?!
My screen is wall mounted and the connections are not readily accesible and this makes flashing a new image a major task for me.
Is there anything simple that can be changed within the BlackHole image so that the Component Out is enabled by default?
Many thanks for reading this far!
Best regards and Happy New Year
Mark
With me so far?!
Mark
