Hbb tv stop running solo2
herc
Does anybody know why the hbbtv services don't running anymore?
ZDF does not work? You only posted the start menus of HbbTv either from ZDF or from those other channel: don't they work?
Anyway, your image is not the last one: we've gone forward with 4.3 and we are now arrived at 4.3.016.
OK, try ZDF or RTL because they use an older version of HbbTv protocol and it works easily.
Instead, other channels, don't work on BH and OBH.
Impossible to answer, as some HbbTv services are geolocated. Others are incompatible, it seems, even if you try to use them from your country. For instance, I can't use any of my country's ones.
ZDF is an example of 1.2 protocol and it is useful to be sure your functionality is installed; that's why I mention it.
A new channel (skai tv) start to running HBBtv and its working good. The protocol must to be the same with the zdf channel.
However, some channels start to running with protocol 2.0.
