HbbTv not working
pe3k
Hi,
I can't get HbbTv to work.. if I switch into a channel has Hbb and I press red button, nothing happens, the user interface dissapears, it shows nothing even if you try to adjust the volume. I have to press exit to be able to switch to another channel and exit the non working HbbTv app.. Does anyone have the same issue? What should I do?
Hi,
Everybody that has Open Blackhole 0.1 on its Stb´s has this issue. It´s already know, and you must be patient and wait for the fix.
