hbbtv problems
basilico
hello, I own the decoder vu + SOLO2.
I installed HbbTV but when I restart the dec the decoder is locked so I came with the PC and I deleted the folder HbbTV under / usr / local. At this point, the decoder is not over 'locked and the list of plugins I get work but when I go to type type google does not start nothing but the internet connection works because I have already downloaded the other plugin and I have no problems.
I did several tests and I also noticed that deleting only hbbtv.app the decoder does not remain locked but when I enter google tells me that even before the browser is started.
Can you help me?
thanks
