HD Glass16 ver. 6.87
mr.strauss
- fix detection plugin browser for BlackPole OE 2.0 (VU+)
- added new option: Enable RadioScreensaver, enable: activate screensaver in
radio mode only, if no infobar, menu, channelselection, ... is displayed (default: disabled)
- updated/fixed pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al translations
- help updated in download
Update is available online via setup
Note: RadioScreensaver is active in Radio mode only
Thx Shamann​
warning
You continue to put these skins on forum with python coding,
that change coding from BH image.
Please note the last time
that we do not provide support for those who use these skins.
And the publication thereof without warning
will not be allowed in the future.
Warning this skin also contains python coding
which may disrupt and modify BH image
use at your own risk.
We do not provide support for the modified image.
Sorry Matrix10, I apoligize , I didn't know it, that is changing python coding.
Seems so innocent skin from outside.
I thought, that author of the skin made it compatible without touching BH internally.
I apologize again, I'll be more carrefull in posting skins.
I found it in postinst. Before author of skin has a patch for BH, so it was clear to everybody, that is changing coding.
Now it's internal and overwrites BH original skin_display.xml and plugin.py. :thanks: for warning me.
This skin is like a virus.
Add many python converters and decrease image peformances.
The most importan teams like Pli and Bh aboslutely disagree with these kind of skins.
REALLY BAD.
Don't use it.
REALLY BAD.
Don't use it.
Thanks, Shiro!
I'm not using it, but when I find something new, I'd like to try.
Could you post a list of most dangerous Skins/Plugins for BH? It could protect a lot of BH users from green screens.
REALLY BAD.
Don't use it.
I always used skin schamann in BH also in VTI never a green screen
saludos elgeneral
LICENSE (TERM OF USE)​
AND THAT'S WHY HD GLASS AND OTHER NOT BH PLUGINS / SKINS ARE FORBIDDEN TO USE WITH BLACK HOLE IMAGES​
Please, remember this!
