Request HD Skin needed please Help
mysat-bs
I would like to try a new skin which must be Simple, Easy to use, Clear fonts, Stable, Good InfoBar, Compatible with BH 2.0.7.2. I have checked many of the posts in Skin Section, but cannot figure out which one is the 'BEST' . Would you please recommand one or offer any suggestion?
Thanks in advance!
There is not "Best Skin". There is only a skin you like or don't. I personally prefer Army Touch.
Thanks, paolino. I understand you said. I will try the Army Touch. I just want to concentrated to a few skins then I can pickup the best suit me. There are too many in the skin section ( I cannot try one by one). Thank you for your recommandation.
You can preview the skins using yellow button when in BH server
