Internal HDD for uno
bearman
Is it possible to fiit HDD in UNO. If so what type is suitable and what is maximum size of TB device that can be used. Image at present is blackhole 2.0.3.
Hi mate
Yes you can install a 3.5" sata hard drive in your uno and I recommend no more than 1tb
You can put in a larger HDD if you upgrade to image 2.0.5 and above. As new BH format utility.... Formats in ext4 faster read/write speeds
I did not have a clue which hdd to install until you suggested the 3.5" sat drive. Ihave just read a post which said if blackhole 2.0.5 was used could increased. Sorry yummer i posted before i say your reply. You have just confirmed the tb size could be increased with blackhole 2.0.5
Well it defo needs a 3.5" hdd, I have a western digital and have no problems with it, surely a 1tb would be more than enough for you.....in my opinion
Well it defo needs a 3.5" hdd, I have a western digital and have problems with it, surely a 1tb would be more than enough for you.....in my opinion
I've only got a 1tb too bud. Plenty for me. Depends on if he wants to use as a media server or likes loads of films ;)
As i am fairly new to linux your replies have been very helpful as i am on a steep learning curve. Readiing between the lines i think 1tb will be more than enough for my usage.
If it's just for normal recording of programmes/movies then 1tb is plenty but as yummer says if you use it as a media server then you will no doubt need more
Yes mate , just for normal recording No doubt i will be crying out for more help when i install hdd . 1 tb will suffice/
Pick a Green Edition 5400RPM drive. Less power is better, speed is not a requirement. Often also cheaper that way!
Using a 500GB WD Green Edition myself, works great. Also that is more than adequate for: Recording purposes + Photo's + Music.
Just ordered toshiba 1tb internal hdd sata 3gb/s 5400rpm 8 mb 2.5" 9.5mm . Price £49.98 +£4.98 24hr delivery . Went for 1tb as price seemed not too bad.
Will be in touch when delivered.
Installed hdd mentioned in previous post. Followed yummers link to installation. Very usefull. Installation was slightly different, maybe because i was installing in uno or because only 2.5".,but figured it out . Mounted ok. All is good. Thanks for feed back.
