HDD missing occasionally in 1.4.3 and 1.4.4
George
Hi.
Since upgrading to 1.4.3 and 1.4.4 the HDD installed in my VU Duo goes missing frequently. Does anybody else suffer from this? Should I mount it manually and if so what is the command I should use? Does anybody know why this is happening and what the solution is?
The HDD is a 1.5TB Samsung HD154UI Spinpoint F2 DT EcoGreen, SATA 3Gb/s, 32MB Cache, 8.9 ms, NCQ
Cheers!
Hi.
Cheers!
Did you mount it by BH Devices Manager?
