tro69
Ho un HDD con due partizioni (ext4 e ntfs) collegato al vu+zero tramite un hub usb con alimentatore.
Il decoder riesce a montare solamente la partizione ntfs, ma non quella etx4. Infatti da "gestione dispositivi" essa risulta non mappata.
Ho provato più volte a montare le due partizioni, anche singolarmente (evitando quindi il mount dell'altra), ma senza successo. Ho provato anche a riflashare l'ultima versione di BH, eseguendo anche gli aggiornamenti.
"cat /proc/mounts" :
"df -h" :
"fdisk -l" :
"blkid" :
"mount" :
"cat /etc/fstab" :
root@vuzero:~# cat /proc/mounts
rootfs / rootfs rw 0 0
ubi0:rootfs / ubifs rw,sync,relatime 0 0
devtmpfs /dev devtmpfs rw,relatime,size=157584k,nr_inodes=39396,mode=755 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,relatime 0 0
tmpfs /run tmpfs rw,nosuid,nodev,mode=755 0 0
tmpfs /var/volatile tmpfs rw,relatime 0 0
/dev/sdb1 /media/video fuseblk rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096 0 0
/dev/sda1 /media/usb ext4 rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,gid=5,mode=620 0 0
/etc/auto.hotplug /autofs autofs rw,relatime,fd=5,pgrp=676,timeout=5,minproto=5,maxproto=5,indirect 0 0
nfsd /proc/fs/nfsd nfsd rw,relatime 0 0
"df -h" :
root@vuzero:~# df -h
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 193.0M 123.7M 69.3M 64% /
devtmpfs 153.9M 4.0K 153.9M 0% /dev
tmpfs 154.0M 388.0K 153.6M 0% /run
tmpfs 154.0M 592.0K 153.4M 0% /var/volatile
/dev/sdb1 638.5G 618.6G 19.9G 97% /media/video
/dev/sda1 1.8G 557.4M 1.2G 31% /media/usb
"fdisk -l" :
root@vuzero:~# fdisk -l
Disk /dev/mtdblock0: 233 MB, 233832448 bytes
255 heads, 63 sectors/track, 28 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 233 MB, 233832448 bytes
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 7 MB, 7340032 bytes
255 heads, 63 sectors/track, 0 cylinders
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 1 MB, 1048576 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/sda: 1998 MB, 1998585856 bytes
30 heads, 30 sectors/track, 4337 cylinders
Units = cylinders of 900 * 512 = 460800 bytes
Device Boot Start End Blocks Id System
/dev/sda1 3 4338 1950720 83 Linux
Disk /dev/sdb: 1000.2 GB, 1000204885504 bytes
255 heads, 63 sectors/track, 121601 cylinders
/dev/sdb1 38245 121602 669561856 7 HPFS/NTFS
/dev/sdb2 1 38245 307198976 83 Linux
Partition table entries are not in disk order
"blkid" :
root@vuzero:~# blkid
/dev/ubi0_0: UUID="a6170222-5a9f-4d3f-9a84-751d339ab45c" TYPE="ubifs"
/dev/sda1: UUID="b1985260-b15d-45c4-8b1f-c7187e2a8865" TYPE="ext2" PARTUUID="3e967416-01"
/dev/sdb1: LABEL="DATI" UUID="7EBDAE2022000F82" TYPE="ntfs" PARTUUID="d7fb9662-01"
/dev/sdb2: LABEL="Registrazioni" UUID="9f410471-e827-4490-b6a2-8c1b478f4be6" TYPE="ext4" PARTUUID="d7fb9662-02"
"mount" :
root@vuzero:~# mount
rootfs on / type rootfs (rw)
ubi0:rootfs on / type ubifs (rw,sync,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=157584k,nr_inodes=39396,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /var/volatile type tmpfs (rw,relatime)
/dev/sdb1 on /media/video type fuseblk (rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096)
/dev/sda1 on /media/usb type ext4 (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
/etc/auto.hotplug on /autofs type autofs (rw,relatime,fd=5,pgrp=676,timeout=5,minproto=5,maxproto=5,indirect)
nfsd on /proc/fs/nfsd type nfsd (rw,relatime)
"cat /etc/fstab" :
root@vuzero:~# cat /etc/fstab
rootfs / auto defaults 1 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
usbdevfs /proc/bus/usb usbdevfs noauto 0 0
tmpfs /run tmpfs mode=0755,nodev,nosuid,strictatime 0 0
tmpfs /var/volatile tmpfs defaults 0 0
tmpfs /dev/shm tmpfs mode=0777 0 0
UUID=7EBDAE2022000F82 /media/video auto defaults 0 0
UUID=9f410471-e827-4490-b6a2-8c1b478f4be6 /media/hdd auto defaults 0 0
UUID=b1985260-b15d-45c4-8b1f-c7187e2a8865 /media/usb auto defaults 0 0
