Hdd problem
Turu
Yesterday install the hard drive and perfect, but if I turn it off without being stsndby to turn it on again I give a record I have to re-start lifting the disc, and there goes all that I have I did not care because they only recorded one thing to test but I can do? You will need to install a skin fault, but I do.
Thank you
vu is just 2, the image is black hole 2.1.0.1 and is internal drive lasted a 1 tb western digital brand
I install the HDD, and it works ok, but if I put vu off, or turn off the switch have to re-initialize the disk and lose all information
You don't have to Reinitialize, only create mount /media/hdd
Blue>Blue>Device Manager>Mountpoints>Select with arrow Left or Right /media/hdd>Red for save
Should be OK.
PS: You didn't answer if it's internal or external, model of your box - Solo2 or Duo2 ?
