hello , i want to ask about hdmi cable which come with vu+4k , this cable is the same which come on the packaging of other vuplus , and it is original ? and finally which version is this cable hmdi 1.3 or 1.4 .??
to get good quality should i buy hmdi2.0 ?
thaanks for reply, matrix10 i didnt understand you what you mean (Pay attention
on some TV sets there is a difference between HDMI inputs.) and the version of this cable is 1.3 or 1.4 ??
HDMI 2.0 vs 1.4: The basics
HDMI 2.0 was announced as a standard in late 2013. It got a lot of people confused, wondering if they suddenly needed to throw away their TVs in order to get on this latest tech trend.
As far as tech advancements go, HDMI 2.0 is a pretty friendly one. It’s as much a standard of software as hardware, and cables designed for HDMI 1.4 systems will work just fine with new HDMI 2.0 devices.
Read more at http://www.trustedreviews.com/opinions/hdmi-2-0-vs-1-4#ul1uXdXGQMfOrBrZ.99
)The cable will be a high speed v1.4 (that is all you need for 4K).hello , i want to ask about hdmi cable which come with vu+4k , this cable is the same which come on the packaging of other vuplus , and it is original ? and finally which version is this cable hmdi 1.3 or 1.4 .??
Supports latest HDMI 2.0 standard (compatible with all HDMI devices)
New supported standards:
- Supports latest standards of HDMI 1.4a and HDMI 2.0
- TV Formats to 21: 9
- Resolutions up to 4096x2160p at 50/60 Hz
- Up to 32 audio channels
- Improved audio quality (up to 1536kHz)
- Higher bandwidth 18 Gbps
- Multiple playback on the same TV screen
- Ethernet over HDMI through additional network channel
- Deep Color to 48bit / sRGB, YCbCr, xvYCC
- Compatible with all HD formats such as 8 PCM, Dolby Digital, DTS, MPEG, DVD-Audio, SACD, Dolby Digital Plus, TrueHD and dts-HD
- Compatible with Dolby True HD 7.1 and DTS HD (up to 32 speakers)
- Compatible with latest TV technologies: OLED displays with 4k resolutions
- Supported resolutions: 480i, 480p, 720i, 720p, 1080i, 1080p, 1440p, 2160p, 4K
- Supports 1080p / 2160p resolution in 3D mode
- HDMI cable 19pin. A male to 19-pin. A plug
- Backward compatible with older HDMI standards (1.0, 1.1, 1.2, 1.3, 1.4) - is automatically detected
- Audio Return Channel (ARC)
- HDCP Compliant
- Multiple shielding (foil + braid)
- Gold-plated contacts for optimum image transfer
- CEC for all HDMI control functions
Supports the technologies of latest generation consoles:
- Playstation 4 and Xbox One. (Ethernet / 4K ULTRA HD)
