HDMI-CEC configuration issue
kujrv1
I want that when i select hdm1 in TV(anynet+), if the vu+ is in standby it power on.
I don't want when power on tv ---> vu+ power on, only when i select hdm1 source.
All other functions with hdmi-cec works ok.
I see in other firmware's it's correctly working (like AAF) but i love BH...
You need to install plugin HDMI-CEC and there you can change this behvaiour.
plugin is installed by default. The configuration that comes with this plugin menu didn't have this options. In AAF didn't have this options in plugin menu but it work's perfectly
With new versión 2.0.2 issue continues.... When i select hdm1 in TV (Samsung), vu+ doesn't exit from stand by
Hello!
I have installed HDMI-CEC with VTI and all works fine:
Switching on the VU, the TV and AV Receiver ist starting. Switching off VU, TV and AV-R ist also switched off
Now I have installed newest Meoboot and some other images.
Now I want the same functions of HDMI
Is this possible?
Which image will now handle HDMI-CEC?
From Flash or image on USB ,or is there a special function in Meoboot?
Thanks in advance
