HDMI CEC Issue with Samsung TV
semtex57
Hello,
I have 2 Solo2 connected each to a samsung TV.
One is from 2012 UE40ES5500
-> Everyting is working fine, I can powerup the TV and Shutdown the TV with the receiver via HDMI CEC
One is from 2008 LE52A676
-> Here I can only powerup the TV, the shutdown function do not work
-> I tried with the standard Canalsat receiver (Cube) and with this one powerup and shutting down.
Are there several differents command to powerup and shutdown ?
can I send command through command line ?
Thanks in advance
I always start from box still switch plasma and onkyo and when shutdown power off box with plasma and onkyo normal to standby.
i have 2 samsung tv one is 46 inch
the other is 55 inch smart tv..
in the green panel in the vu+
hdmi cec hdmi-cec configaration
i have
vu standby=>tv activity: Tv standby
so when i switch vu+ off.. vu+ and tv both go to standby..
hope this help you.
rg tm
I have the same issue with Samsung Ue22c4000 and Vu Duo (BH 2.1.3). Even if I set (on TV) in Application/Anynet+(HDMI-CEC) /Setup --> "Auto Turn off" which would turn off at the same time the device equipped with HDMI-CEC and TV, this procedure is not stored on TV so every time I turn off the TV and power on again, when I try to switch off the TV from decoder this one don't shutdown and "Auto Turn off" on TV came back to "No" from "Yes" that I tried to set up.
more info please
can you show how you have setup in the vu
I have 2 samsungs working good using hdmi-cec on my vu+ boxes
