hdmi-cec no passthrough to receiver
dropsman
hi,
I managed to setup hdmi-cec without problems.
If I press A/V receiver volume up/down or mute in the hdmi-cec plugin menu it works like a charme.
If i press volume up/down or mute in normal use it changes the volume from the vuplus and NOT of the A/V receiver.
My Hardware: VU+ Uno BH 2.0.5 rev B, Sony TV, Onkyo A/V
How can i set the volumecontrol to passthrough to the A/V receiver in the BH image?
In other images there is a option for that.
Thanx
Hi,
i have seen that there is this entry in the settings file of other images : config.hdmicec.volume_forwarding=true
If i put this line in the file it will be writen, but after a reboot the entry is not in there anymore.....
How can i change the file permanently?
Thanx
hi,
Thanx
I think you should set your Vu+ remote control to work with your TV.
In this way you can use directly TV volume control and when the AV receiver is switched on it's volume should be controlled by the same remote control.
@mito:
This is not a solution.... Why we have CEC???? In other images this is working without problems.....
How can i set the 'forward' option in the settings file???
Thanx
@mito:
Thanx
Cec into BH images is the one developed by vu+ forking the original pli code.
Ask directly vu+ to implement the function you need
iPhone 5 & Tapatalk forever :)
Hi all,
thanx for the answer. This means that the plugin in the vti and aaf image is a fork of the original code?
How can i set this line for test in the settings file?
Thanx
