Solo2 HDMI output does not work
schiltronics
my SOLO2 HDMI output does not work
Scart works
already tried new hdmi cable, new software, etc.
someone has a solution
best regarts
gie
What image are you using?
Have you set the video output for HDMI, and the correct resolution, 720, 1080p, 1080i, depending on your television?
I tried with vti, open pli and the original
scart works
HDMI does not work
all settings are correct
think SOLO2 is broken
there is a solution
the seller said to send importer but then I lost him a month
I can not repair it myself ?
I'm not the only one where hdmi not working
If the box is into warranty period and you have the bill, the seller cannot said that!
He cannot ignore your warranty request.
My HDMI-Output of my Solo (not solo2) also does not work.
Does anyone has a link to the schematic diagram of the receiver ?
