Hello help on set iPad OpenWebif and Duo2
isim
Hello,
My configuration :
Only one LNB, Astra coming on my dvb 1 in.
The out of dvb 1 is connected with a cable on the dvb 2 in.
I have acces with my iPad to the box, can see the channel lits but can't see the streaming. I would like to watch a Channel on TV and an other on my iPad.
Many thanks for your helps
Hello,
My configuration :
You should use Vu+ Player app to get all features
Hi,
Thank you for your answer. I try it but dosent work. Error ... Try again in 3 seconds.
I try it from a PC and it works perfectly over openwebif. So my configuration on the box is OK.
I think my iPhone and iPad arent able to read the streaming even in VU+HD or VU+ players or openwebif on telnet.
Thank you all for u'r help.
