Hi, I can not play in kodi from my qnap
the screen stays black and time does not pass.
from vu + and mediaplayer2 if you play them but since kodi no
here my log file
if you can help me
I am sorry for my bad english
here my log file
10:04:41.215 T:3037875344 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:04:41.215 T:3037875344 NOTICE: -----------------------------------------------------------------------
10:04:41.215 T:3037875344 NOTICE: Starting Kodi (17.4 Git:2017-10-20-7fc6da0-dirty). Platform: Linux ARM 32-bit
10:04:41.215 T:3037875344 NOTICE: Using Release Kodi x32 build
10:04:41.215 T:3037875344 NOTICE: Kodi compiled Oct 20 2017 by GCC 6.3.0 for Linux ARM 32-bit version 3.19.0 (201472)
10:04:41.215 T:3037875344 NOTICE: Running on openbh 1.0, kernel: Linux ARM 32-bit version 3.14.28-1.12
10:04:41.215 T:3037875344 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
10:04:41.215 T:3037875344 NOTICE: Host CPU: ARMv7 Processor rev 3 (v7l), 4 cores available
10:04:41.215 T:3037875344 NOTICE: ARM Features: Neon enabled
10:04:41.215 T:3037875344 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
10:04:41.215 T:3037875344 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
10:04:41.215 T:3037875344 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
10:04:41.215 T:3037875344 NOTICE: special://masterprofile/ is mapped to: /media/hdd/.kodi/userdata
10:04:41.215 T:3037875344 NOTICE: special://envhome/ is mapped to: /media/hdd
10:04:41.215 T:3037875344 NOTICE: special://home/ is mapped to: /media/hdd/.kodi
10:04:41.216 T:3037875344 NOTICE: special://temp/ is mapped to: /tmp/kodi
10:04:41.216 T:3037875344 NOTICE: special://logpath/ is mapped to: /tmp/kodi
10:04:41.216 T:3037875344 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
10:04:41.216 T:3037875344 NOTICE: Local hostname: vuultimo4k
10:04:41.216 T:3037875344 NOTICE: Log File is located: /tmp/kodi//kodi.log
10:04:41.216 T:3037875344 NOTICE: -----------------------------------------------------------------------
10:04:41.217 T:3037875344 NOTICE: load settings...
10:04:41.235 T:3037875344 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
10:04:41.264 T:3037875344 NOTICE: No Devices found - retry: 4
10:04:42.782 T:3037875344 NOTICE: No Devices found - retry: 3
10:04:44.300 T:3037875344 NOTICE: No Devices found - retry: 2
10:04:45.817 T:3037875344 NOTICE: No Devices found - retry: 1
10:04:47.335 T:3037875344 NOTICE: Found 0 Lists of Devices
10:04:47.349 T:3037875344 NOTICE: No Devices found - retry: 4
10:04:48.867 T:3037875344 NOTICE: No Devices found - retry: 3
10:04:50.385 T:3037875344 NOTICE: No Devices found - retry: 2
10:04:51.902 T:3037875344 NOTICE: No Devices found - retry: 1
10:04:53.420 T:3037875344 NOTICE: Found 0 Lists of Devices
10:04:53.427 T:3037875344 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:04:53.427 T:3037875344 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
10:04:53.427 T:3037875344 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.120</host>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
</videolibrary>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>209715200</cachemembuffersize>
<readbufferfactor>10</readbufferfactor>
</network>
</advancedsettings>
10:04:53.427 T:3037875344 WARNING: VIDEO database configuration is experimental.
10:04:53.428 T:3037875344 NOTICE: Default Video Player: VideoPlayer
10:04:53.428 T:3037875344 NOTICE: Default Audio Player: paplayer
10:04:53.428 T:3037875344 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:04:53.428 T:3037875344 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:04:53.428 T:3037875344 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:04:53.428 T:3037875344 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:04:53.429 T:3037875344 WARNING: CPlayerCoreFactory::GetPlayer(E2Player): no such player: E2Player
10:04:53.429 T:3037875344 NOTICE: Loaded playercorefactory configuration
10:04:53.429 T:3037875344 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:04:53.429 T:3037875344 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:04:53.443 T:3037875344 NOTICE: Running database version Addons27
10:04:53.537 T:3037875344 NOTICE: ADDONS: Using repository repository.xbmc.org
10:04:53.556 T:3008361456 NOTICE: No Devices found - retry: 4
10:04:55.073 T:3008361456 NOTICE: No Devices found - retry: 3
10:04:56.592 T:3008361456 NOTICE: No Devices found - retry: 2
10:04:58.109 T:3008361456 NOTICE: No Devices found - retry: 1
10:04:59.627 T:3008361456 NOTICE: Found 0 Lists of Devices
10:04:59.638 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:04:59.666 T:3037875344 NOTICE: InitWindowSystem: Using EGL Implementation: vuplus
10:05:01.008 T:3037875344 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
10:05:01.008 T:3037875344 NOTICE: Previous line repeats 2 times.
10:05:01.008 T:3037875344 NOTICE: Found (1280x720@50.000000) at 16, setting to RES_DESKTOP at 16
10:05:01.008 T:3037875344 NOTICE: Checking resolution 16
10:05:01.009 T:3037875344 NOTICE: GL_VENDOR = Broadcom
10:05:01.009 T:3037875344 NOTICE: GL_RENDERER = VideoCore IV HW (V3D-435)
10:05:01.009 T:3037875344 NOTICE: GL_VERSION = OpenGL ES 2.0
10:05:01.009 T:3037875344 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
10:05:01.009 T:3037875344 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888 GL_EXT_read_format_bgra GL_OES_EGL_sync
10:05:01.459 T:3017798640 NOTICE: Running database version Addons27
10:05:01.461 T:3017798640 NOTICE: Running database version ViewModes6
10:05:01.463 T:3017798640 NOTICE: Running database version Textures13
10:05:01.472 T:3017798640 NOTICE: Running database version MyMusic60
10:05:01.478 T:3017798640 NOTICE: Running database version MyVideos107
10:05:01.480 T:3017798640 NOTICE: Running database version TV29
10:05:01.481 T:3017798640 NOTICE: Running database version Epg11
10:05:01.704 T:3037875344 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
10:05:01.988 T:3037875344 NOTICE: initialize done
10:05:01.988 T:3037875344 NOTICE: Running the application...
10:05:01.999 T:3037875344 NOTICE: starting zeroconf publishing
10:05:01.999 T:3037875344 NOTICE: starting upnp client
10:05:02.006 T:2308961264 NOTICE: ES: Starting UDP Event server on port 9777
10:05:02.006 T:2308961264 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
10:05:07.628 T:3037875344 NOTICE: ExternalPlayer Filename: kodiext
10:05:07.628 T:3037875344 WARNING: ExternalPlayer: invalid value for warpcursor: none
10:05:07.628 T:3037875344 NOTICE: ExternalPlayer Tweaks: hideconsole (true), hidexbmc (true), islauncher (false), warpcursor (none)
10:05:07.628 T:3037875344 NOTICE: OpenFile: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/David Gilmour-Remember That Night (2007)/David Gilmour Remember That Night (2007).CD2.mkv
10:05:07.629 T:2408256496 NOTICE: Process: Player : kodiext
10:05:07.629 T:2408256496 NOTICE: Process: File : smb://NAS-QNAP/Multimedia/Videos Blu-Ray/David Gilmour-Remember That Night (2007)/David Gilmour Remember That Night (2007).CD2.mkv
10:05:07.629 T:2408256496 NOTICE: Process: Content:
10:05:07.629 T:2408256496 NOTICE: Process: Args : -U "{1}" -S "{3}" -P "$PPID"
10:05:07.629 T:2408256496 NOTICE: Process: Start
10:05:07.629 T:2408256496 NOTICE: Process: Hiding Kodi window
10:05:07.829 T:2408256496 NOTICE: ExecuteAppLinux: "kodiext" -U "smb://NAS-QNAP/Multimedia/Videos Blu-Ray/David Gilmour-Remember That Night (2007)/David Gilmour Remember That Night (2007).CD2.mkv" -S "{3}" -P "$PPID"
10:05:16.387 T:2408256496 NOTICE: Process: Stop
10:05:16.387 T:2408256496 NOTICE: Process: Showing Kodi window
10:05:16.403 T:3008361456 NOTICE: No Devices found - retry: 4
10:05:17.921 T:3008361456 NOTICE: No Devices found - retry: 3
10:05:19.440 T:3008361456 NOTICE: No Devices found - retry: 2
10:05:20.958 T:3008361456 NOTICE: No Devices found - retry: 1
10:05:21.387 T:2408256496 ERROR: ActiveAE::Resume - failed to init
10:05:21.387 T:2408256496 FATAL: Process: Failed to restart AudioEngine after return from external player
10:05:22.484 T:3008361456 NOTICE: Found 0 Lists of Devices
10:05:22.498 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:05:31.544 T:2370229232 ERROR: GetDirectory - Error getting
10:05:55.448 T:3037875344 ERROR: Previous line repeats 6 times.
10:05:55.448 T:3037875344 NOTICE: VideoPlayer: Opening: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:05:55.448 T:3037875344 WARNING: CDVDMessageQueue(player):ut MSGQ_NOT_INITIALIZED
10:05:55.448 T:2989487088 NOTICE: Creating InputStream
10:05:55.462 T:2989487088 NOTICE: Creating Demuxer
10:05:55.539 T:2989487088 NOTICE: Opening stream: 0 source: 256
10:05:55.539 T:2989487088 NOTICE: Creating video codec with codec id: 28
10:05:55.539 T:2989487088 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
10:05:55.540 T:2989487088 NOTICE: Creating video thread
10:05:55.541 T:2989487088 NOTICE: Opening stream: 1 source: 256
10:05:55.541 T:2141660144 NOTICE: running thread: video_thread
10:05:55.541 T:2989487088 NOTICE: Finding audio codec for: 86019
10:05:55.542 T:2989487088 NOTICE: Creating audio thread
10:05:55.542 T:2133271536 NOTICE: running thread: CVideoPlayerAudio:rocess()
10:05:55.562 T:2133271536 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
10:05:55.782 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 250 ms, reducing to 100 ms
10:05:55.796 T:3037875344 NOTICE: Using GL_TEXTURE_2D
10:05:55.807 T:3037875344 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
10:05:55.854 T:3037875344 NOTICE: GL: NPOT texture support detected
10:05:56.605 T:2141660144 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727
10:06:15.121 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:15.121 T:3037875344 NOTICE: VideoPlayer: waiting for threads to exit
10:06:15.125 T:2989487088 NOTICE: CVideoPlayer::OnExit()
10:06:15.125 T:2989487088 NOTICE: Closing stream player 1
10:06:15.125 T:2989487088 NOTICE: Waiting for audio thread to exit
10:06:15.211 T:2133271536 NOTICE: thread end: CVideoPlayerAudio::OnExit()
10:06:15.211 T:2989487088 NOTICE: Closing audio device
10:06:15.302 T:2141660144 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
10:06:15.336 T:2989487088 NOTICE: Deleting audio codec
10:06:15.336 T:2989487088 NOTICE: Closing stream player 2
10:06:15.336 T:2989487088 NOTICE: waiting for video thread to exit
10:06:15.353 T:2141660144 NOTICE: thread end: video_thread
10:06:15.354 T:2989487088 NOTICE: deleting video codec
10:06:15.387 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:06:15.425 T:3037875344 NOTICE: VideoPlayer: finished waiting
10:06:15.433 T:3037875344 NOTICE: VideoPlayer: Opening: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:06:15.433 T:2989487088 NOTICE: Creating InputStream
10:06:15.445 T:2989487088 NOTICE: Creating Demuxer
10:06:15.472 T:2989487088 NOTICE: Opening stream: 0 source: 256
10:06:15.473 T:2989487088 NOTICE: Creating video codec with codec id: 28
10:06:15.473 T:2989487088 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
10:06:15.478 T:2989487088 NOTICE: Creating video thread
10:06:15.478 T:2989487088 NOTICE: Opening stream: 1 source: 256
10:06:15.478 T:2214253552 NOTICE: running thread: video_thread
10:06:15.478 T:2989487088 NOTICE: Finding audio codec for: 86019
10:06:15.479 T:2989487088 NOTICE: Creating audio thread
10:06:15.479 T:2202006512 NOTICE: running thread: CVideoPlayerAudio:rocess()
10:06:15.533 T:2202006512 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
10:06:15.930 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 250 ms, reducing to 100 ms
10:06:15.934 T:3037875344 NOTICE: Using GL_TEXTURE_2D
10:06:15.985 T:3037875344 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
10:06:16.024 T:3037875344 NOTICE: GL: NPOT texture support detected
10:06:16.778 T:2214253552 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41636
10:06:19.461 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:19.461 T:3037875344 NOTICE: VideoPlayer: waiting for threads to exit
10:06:19.468 T:2989487088 NOTICE: CVideoPlayer::OnExit()
10:06:19.468 T:2989487088 NOTICE: Closing stream player 1
10:06:19.468 T:2989487088 NOTICE: Waiting for audio thread to exit
10:06:19.571 T:2202006512 NOTICE: thread end: CVideoPlayerAudio::OnExit()
10:06:19.571 T:2989487088 NOTICE: Closing audio device
10:06:19.695 T:2989487088 NOTICE: Deleting audio codec
10:06:19.695 T:2989487088 NOTICE: Closing stream player 2
10:06:19.695 T:2989487088 NOTICE: waiting for video thread to exit
10:06:19.733 T:2214253552 NOTICE: thread end: video_thread
10:06:19.733 T:2989487088 NOTICE: deleting video codec
10:06:19.751 T:3037875344 NOTICE: VideoPlayer: finished waiting
10:06:19.759 T:3037875344 NOTICE: VideoPlayer: Opening: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:06:19.759 T:2989487088 NOTICE: Creating InputStream
10:06:19.768 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:06:19.771 T:2989487088 NOTICE: Creating Demuxer
10:06:19.800 T:2989487088 NOTICE: Opening stream: 0 source: 256
10:06:19.800 T:2989487088 NOTICE: Creating video codec with codec id: 28
10:06:19.800 T:2989487088 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
10:06:19.802 T:2989487088 NOTICE: Creating video thread
10:06:19.802 T:2989487088 NOTICE: Opening stream: 1 source: 256
10:06:19.802 T:2202006512 NOTICE: running thread: video_thread
10:06:19.802 T:2989487088 NOTICE: Finding audio codec for: 86019
10:06:19.803 T:2989487088 NOTICE: Creating audio thread
10:06:19.803 T:2163209200 NOTICE: running thread: CVideoPlayerAudio:rocess()
10:06:19.828 T:2163209200 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
10:06:20.220 T:3037875344 NOTICE: Using GL_TEXTURE_2D
10:06:20.241 T:3037875344 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
10:06:20.280 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 250 ms, reducing to 100 ms
10:06:20.306 T:3037875344 NOTICE: GL: NPOT texture support detected
10:06:21.066 T:2202006512 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727
10:06:21.419 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:21.419 T:3037875344 NOTICE: VideoPlayer: waiting for threads to exit
10:06:21.429 T:2989487088 NOTICE: CVideoPlayer::OnExit()
10:06:21.429 T:2989487088 NOTICE: Closing stream player 1
10:06:21.429 T:2989487088 NOTICE: Waiting for audio thread to exit
10:06:21.663 T:2163209200 NOTICE: thread end: CVideoPlayerAudio::OnExit()
10:06:21.663 T:2989487088 NOTICE: Closing audio device
10:06:21.788 T:2989487088 NOTICE: Deleting audio codec
10:06:21.788 T:2989487088 NOTICE: Closing stream player 2
10:06:21.788 T:2989487088 NOTICE: waiting for video thread to exit
10:06:21.813 T:2202006512 NOTICE: thread end: video_thread
10:06:21.814 T:2989487088 NOTICE: deleting video codec
10:06:21.830 T:3037875344 NOTICE: VideoPlayer: finished waiting
10:06:21.837 T:3037875344 NOTICE: VideoPlayer: Opening: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:06:21.838 T:2989487088 NOTICE: Creating InputStream
10:06:21.850 T:2989487088 NOTICE: Creating Demuxer
10:06:21.881 T:2989487088 NOTICE: Opening stream: 0 source: 256
10:06:21.881 T:2989487088 NOTICE: Creating video codec with codec id: 28
10:06:21.881 T:2989487088 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
10:06:21.882 T:2989487088 NOTICE: Creating video thread
10:06:21.883 T:2989487088 NOTICE: Opening stream: 1 source: 256
10:06:21.883 T:2202006512 NOTICE: running thread: video_thread
10:06:21.883 T:2989487088 NOTICE: Finding audio codec for: 86019
10:06:21.884 T:2989487088 NOTICE: Creating audio thread
10:06:21.884 T:2163209200 NOTICE: running thread: CVideoPlayerAudio:rocess()
10:06:21.907 T:2163209200 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
10:06:22.016 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:06:22.171 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 250 ms, reducing to 100 ms
10:06:22.244 T:3037875344 NOTICE: Using GL_TEXTURE_2D
10:06:22.282 T:3037875344 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
10:06:22.320 T:3037875344 NOTICE: GL: NPOT texture support detected
10:06:22.726 T:2202006512 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727
10:06:23.789 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:23.789 T:3037875344 NOTICE: VideoPlayer: waiting for threads to exit
10:06:23.795 T:2989487088 NOTICE: CVideoPlayer::OnExit()
10:06:23.795 T:2989487088 NOTICE: Closing stream player 1
10:06:23.795 T:2989487088 NOTICE: Waiting for audio thread to exit
10:06:24.071 T:2163209200 NOTICE: thread end: CVideoPlayerAudio::OnExit()
10:06:24.071 T:2989487088 NOTICE: Closing audio device
10:06:24.196 T:2989487088 NOTICE: Deleting audio codec
10:06:24.196 T:2989487088 NOTICE: Closing stream player 2
10:06:24.196 T:2989487088 NOTICE: waiting for video thread to exit
10:06:24.199 T:2202006512 NOTICE: thread end: video_thread
10:06:24.199 T:2989487088 NOTICE: deleting video codec
10:06:24.215 T:3037875344 NOTICE: VideoPlayer: finished waiting
10:06:24.223 T:3037875344 NOTICE: VideoPlayer: Opening: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:06:24.223 T:2989487088 NOTICE: Creating InputStream
10:06:24.235 T:2989487088 NOTICE: Creating Demuxer
10:06:24.259 T:2989487088 NOTICE: Opening stream: 0 source: 256
10:06:24.259 T:2989487088 NOTICE: Creating video codec with codec id: 28
10:06:24.259 T:2989487088 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
10:06:24.262 T:2989487088 NOTICE: Creating video thread
10:06:24.262 T:2989487088 NOTICE: Opening stream: 1 source: 256
10:06:24.262 T:2408256496 NOTICE: running thread: video_thread
10:06:24.262 T:2989487088 NOTICE: Finding audio codec for: 86019
10:06:24.263 T:2989487088 NOTICE: Creating audio thread
10:06:24.263 T:2202006512 NOTICE: running thread: CVideoPlayerAudio:rocess()
10:06:24.306 T:2202006512 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
10:06:24.690 T:3037875344 NOTICE: Using GL_TEXTURE_2D
10:06:24.701 T:3037875344 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
10:06:24.742 T:3037875344 NOTICE: GL: NPOT texture support detected
10:06:25.376 T:2408256496 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41636
10:06:50.612 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:50.612 T:3037875344 NOTICE: VideoPlayer: waiting for threads to exit
10:06:50.619 T:2989487088 NOTICE: CVideoPlayer::OnExit()
10:06:50.619 T:2989487088 NOTICE: Closing stream player 1
10:06:50.619 T:2989487088 NOTICE: Waiting for audio thread to exit
10:06:50.868 T:2202006512 NOTICE: thread end: CVideoPlayerAudio::OnExit()
10:06:50.868 T:2989487088 NOTICE: Closing audio device
10:06:50.993 T:2989487088 NOTICE: Deleting audio codec
10:06:50.993 T:2989487088 NOTICE: Closing stream player 2
10:06:50.993 T:2989487088 NOTICE: waiting for video thread to exit
10:06:51.009 T:2408256496 NOTICE: thread end: video_thread
10:06:51.010 T:2989487088 NOTICE: deleting video codec
10:06:51.031 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:06:51.033 T:3037875344 NOTICE: VideoPlayer: finished waiting
10:06:51.604 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:51.605 T:3037875344 NOTICE: VideoPlayer: waiting for threads to exit
10:06:51.605 T:3037875344 NOTICE: VideoPlayer: finished waiting
10:06:51.605 T:3037875344 NOTICE: CVideoPlayer::CloseFile()
10:06:52.915 T:3037875344 NOTICE: ExternalPlayer Filename: kodiext
10:06:52.915 T:3037875344 WARNING: ExternalPlayer: invalid value for warpcursor: none
10:06:52.915 T:3037875344 NOTICE: ExternalPlayer Tweaks: hideconsole (true), hidexbmc (true), islauncher (false), warpcursor (none)
10:06:52.915 T:3037875344 NOTICE: OpenFile: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:06:52.915 T:2989487088 NOTICE: Process: Player : kodiext
10:06:52.915 T:2989487088 NOTICE: Process: File : smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv
10:06:52.915 T:2989487088 NOTICE: Process: Content:
10:06:52.915 T:2989487088 NOTICE: Process: Args : -U "{1}" -S "{3}" -P "$PPID"
10:06:52.915 T:2989487088 NOTICE: Process: Start
10:06:52.915 T:2989487088 NOTICE: Process: Hiding Kodi window
10:06:53.466 T:2989487088 NOTICE: ExecuteAppLinux: "kodiext" -U "smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC - Live at River Plate (2009)/AC DC - Live at River Plate (2009).mkv" -S "{3}" -P "$PPID"
10:08:11.980 T:2989487088 NOTICE: Process: Stop
10:08:11.980 T:2989487088 NOTICE: Process: Showing Kodi window
10:08:11.996 T:3008361456 NOTICE: No Devices found - retry: 4
10:08:13.514 T:3008361456 NOTICE: No Devices found - retry: 3
10:08:15.031 T:3008361456 NOTICE: No Devices found - retry: 2
10:08:16.549 T:3008361456 NOTICE: No Devices found - retry: 1
10:08:16.980 T:2989487088 ERROR: ActiveAE::Resume - failed to init
10:08:16.981 T:2989487088 FATAL: Process: Failed to restart AudioEngine after return from external player
10:08:16.981 T:3037875344 NOTICE: ExternalPlayer Filename: kodiext
10:08:16.981 T:3037875344 WARNING: ExternalPlayer: invalid value for warpcursor: none
10:08:16.981 T:3037875344 NOTICE: ExternalPlayer Tweaks: hideconsole (true), hidexbmc (true), islauncher (false), warpcursor (none)
10:08:16.981 T:3037875344 NOTICE: OpenFile: smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC Live at Donington (1992)/AC DC Live at Donington (1992).mkv
10:08:16.981 T:2989487088 NOTICE: Process: Player : kodiext
10:08:16.981 T:2989487088 NOTICE: Process: File : smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC Live at Donington (1992)/AC DC Live at Donington (1992).mkv
10:08:16.981 T:2989487088 NOTICE: Process: Content:
10:08:16.981 T:2989487088 NOTICE: Process: Args : -U "{1}" -S "{3}" -P "$PPID"
10:08:16.981 T:2989487088 NOTICE: Process: Start
10:08:16.981 T:2989487088 NOTICE: Process: Hiding Kodi window
10:08:16.981 T:2989487088 NOTICE: ExecuteAppLinux: "kodiext" -U "smb://NAS-QNAP/Multimedia/Videos Blu-Ray/AC DC Live at Donington (1992)/AC DC Live at Donington (1992).mkv" -S "{3}" -P "$PPID"
10:08:18.067 T:3008361456 NOTICE: Found 0 Lists of Devices
10:08:18.078 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
10:09:27.703 T:2989487088 NOTICE: Process: Stop
10:09:27.703 T:2989487088 NOTICE: Process: Showing Kodi window
10:09:27.719 T:3008361456 NOTICE: No Devices found - retry: 4
10:09:29.237 T:3008361456 NOTICE: No Devices found - retry: 3
10:09:30.788 T:3008361456 NOTICE: No Devices found - retry: 2
10:09:32.314 T:3008361456 NOTICE: No Devices found - retry: 1
10:09:32.703 T:2989487088 ERROR: ActiveAE::Resume - failed to init
10:09:32.703 T:2989487088 FATAL: Process: Failed to restart AudioEngine after return from external player
10:09:32.704 T:3037875344 NOTICE: ExternalPlayer Filename: kodiext
10:09:32.704 T:3037875344 WARNING: ExternalPlayer: invalid value for warpcursor: none
10:09:32.704 T:3037875344 NOTICE: ExternalPlayer Tweaks: hideconsole (true), hidexbmc (true), islauncher (false), warpcursor (none)
10:09:32.704 T:3037875344 NOTICE: OpenFile: smb://NAS-QNAP/Multimedia/Peliculas Animacion/Albert (2015)/Albert (2015).avi
10:09:32.704 T:2989487088 NOTICE: Process: Player : kodiext
10:09:32.704 T:2989487088 NOTICE: Process: File : smb://NAS-QNAP/Multimedia/Peliculas Animacion/Albert (2015)/Albert (2015).avi
10:09:32.704 T:2989487088 NOTICE: Process: Content:
10:09:32.704 T:2989487088 NOTICE: Process: Args : -U "{1}" -S "{3}" -P "$PPID"
10:09:32.704 T:2989487088 NOTICE: Process: Start
10:09:32.704 T:2989487088 NOTICE: Process: Hiding Kodi window
10:09:32.704 T:2989487088 NOTICE: ExecuteAppLinux: "kodiext" -U "smb://NAS-QNAP/Multimedia/Peliculas Animacion/Albert (2015)/Albert (2015).avi" -S "{3}" -P "$PPID"
10:09:33.832 T:3008361456 NOTICE: Found 0 Lists of Devices
10:09:33.843 T:3008361456 WARNING: ActiveAE::Configure - sink returned large buffer of 249 ms, reducing to 100 ms
<advancedsettings>
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</musicdatabase>
<videolibrary>
</videolibrary>
<network>
</network>
</advancedsettings>
if you can help me
