HELP - After upgrading to 2.0.2 rev D receiver in loop
luismgh
Hi,
After upgrading to 2.0.2 rev D receiver entered in loop and cannot start due to green screens.
Any help is aprecciated.
Regards,
It is not a specific BH problem.
The biggest problem with online updates
is just full flash.
Images become larger.
Users fill the rest of the flash and then it's impossible to make
online update without any problems.
(Only if you have a place in a flash)
Most of the updates in the older boxes is therefore problematic
I think that users should make more use of Black Hole Speed ​​Up
and remove not used ,to free flash for updates.
Therefore, I am always a fan of installing clean image.
is just full flash.
I did what you say. I had only 3 or 4 plugins because i used Black Hole Speed up feature. Even tough the problem happened.
Are U using other skins than the one for BH from the server?
Can U upload the crash log!
when upgrading by TELNET:
Collected errors:
* parse_from_stream_nomalloc: Missing new line character at end of file!
* pkg_get_installed_files: Failed to open //var/lib/opkg/info/opera-hbbtv.list:
No such file or directory.
* pkg_get_installed_files: Failed to open //var/lib/opkg/info/enigma2-plugin-sy
stemplugins-videoenhancement.list: No such file or directory.
* pkg_get_installed_files: Failed to open //var/lib/opkg/info/libdvdcss2.list:
stemplugins-videomode.list: No such file or directory.
stemplugins-commoninterfaceassignment.list: No such file or directory.
stemplugins-softwaremanager.list: No such file or directory.
* pkg_get_installed_files: Failed to open //var/lib/opkg/info/enigma2-plugin-ex
tensions-streamtv.list: No such file or directory.
tensions-dvdplayer.list: No such file or directory.
* pkg_get_installed_files: Failed to open //var/lib/opkg/info/enigma2.list: No
stemplugins-wirelesslansetup.list: No such file or directory.
tensions-mediaplayer.list: No such file or directory.
stemplugins-factorytest.list: No such file or directory.
stemplugins-hdmicec.list: No such file or directory.
stemplugins-zappingmodeselection.list: No such file or directory.
