Help building up new image
hazzhass
I would like to build new image, like BH, I know vu is open source , but I need help compiling Enigma2 file.
Can one of BH team, senior coder like angelofsky , help, I need the bh Enigma2 file..
thanks for cooperation
I looked at Enigma2 experimental, but it lacks a lot of codes, eg info panel eGauge, hbbtv ...
Can i use BH Enigma2 or if you kind enough show me these codes..
Thanks
Thanks
You have possibility based on opensource code who is in BP or on others.
If Im good understend you can made image based on Bh code ? I think this inpossible .........
Yes this is my question, can I make image on BH code???
Unfortunately as far as I know it can not ,
It seems to me you to have experience with images
then you could modify code in the BP image , and make something similar.
but beware BH skins graphics are not open source , only BP skins.
Obvious, I don't understand the DISCLAIMER & LICENSE of BH image.
DISCLAIMER
LICENSE (TERM OF USE)
I do not know what you do not understand?
We do not want to be responsible for any image modifications .
So any modifications mean your responsibility.
The same applies to the use of image
we make images on a hobby basis and using images is at your own risk.
And one other thing also important image is based on VU+ image coding
for most of the important elements of the image.
We are not the sort of company,
that for users and the use of image carries responsibility.
So it all depends on you as a user , you are free to use
or not to use image.
About support for the other boxes .
We do not support Clone boxes and boxes from other companies.
therefore only the original VU + receivers.
So our images are not at all intended to use in such boxes,
different from the original.
And we do not test our images on these boxes.
They have no support on our forum and our team.
and then what about #5 ??
So that's already been answered,
I understand in which direction you want to go
What is the point of BH code if already exists BH image.
The aim of this could just be a modification or use our work for the purpose for which it was not intended.
THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY
So I think we finished the discussion.
Of course you understand me, never doubt about that :-)
My only direction what that I thought that answer of #5
should have reflected disclaimer and license, which I respect.
and yes we can end there
All I want is bh enigma2 file, not interested in skins etc.. I have friend skinner
How do you mean " I want"
So we posted that we do not have it start with official DVBApp from Vu+.
Time to close because , we have respond to your questions.
