HELP can not watch second channel with a DUAL TUNER ON OPENVIX DUO2
hardy27
Hello,
I have a Vu+ Duo2 with a DUAL tuner (x1 tuner with 2 LNB inputs), however as soon as i start recording a channel it stops me from viewing a second channel. Why is this?
to be thorough:
1) Both separate cable feeds have good signal strength and quality.
2) sat-finder shows signal strength.
3) tried tuner config and kept both A and B simple on 28.2e
Tested both cables with a duo and solo2 and no issues so it cant be the cable run or lnb.
Please Help
Hello,
to be thorough:
Please Help
This is Black Hole forum.
However, I think if the cable is coming from one LNB, it may not work especially for HD channels because of polarities!
Hello,
to be thorough:
Please Help
Does it stop you from watching only pay channels or free to air channels as well?
If it's only pay channels, then I would say upgrade your ******* to a later version.
If it's free to air channels as well, then you need to look at whether your tuner configurations is correct.
Banned. No EMU support here.
