Come potrei risolvere?
EXCEPTION IN PYTHON STARTUP CODE:
File "/usr/lib/enigma2/python/mytest.py", line 591, in <module>
runScreenTest()
File "/usr/lib/enigma2/python/mytest.py", line 485, in runScreenTest
runNextScreen(session, screensToRun)
File "/usr/lib/enigma2/python/mytest.py", line 479, in runNextScreen
session.openWithCallback(boundFunction(runNextScreen, session, screensToRun[1:]), screen, *args)
File "/usr/lib/enigma2/python/mytest.py", line 302, in openWithCallback
dlg = self.open(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 315, in open
self.execBegin()
File "/usr/lib/enigma2/python/mytest.py", line 213, in execBegin
self.summary = self.instantiateSummaryDialog(summary, c)
File "/usr/lib/enigma2/python/mytest.py", line 254, in instantiateSummaryDialog
return self.doInstantiateDialog(screen, arguments, kwargs, self.summary_desktop)
File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog
dlg.applySkin()
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin
self.createGUIScreen(self.instance, self.desktop)
File "/usr/lib/enigma2/python/Components/GUISkin.py", line 21, in createGUIScreen
if not val.applySkin(desktop, self):
File "/usr/lib/enigma2/python/Components/GUIComponent.py", line 39, in applySkin
skin.applyAllAttributes(self.instance, desktop, self.skinAttributes, parent.scale)
File "/usr/lib/enigma2/python/skin.py", line 308, in applyAllAttributes
applySingleAttribute(guiObject, desktop, attrib, value, scale)
File "/usr/lib/enigma2/python/skin.py", line 208, in applySingleAttribute
ptr = loadPixmap(value, desktop) # this should already have been filename-resolved.
File "/usr/lib/enigma2/python/skin.py", line 176, in loadPixmap
raise SkinError("pixmap file %s not found!" % (path))
SkinError: {skin.xml}: pixmap file /usr/share/enigma2/vfd_icons/vfd_icon_rec.png not found!
(exit code 5)
Appena posso provo.e invece per cancellare il plugin dei picons?(loghi dei canali)Code:EXCEPTION IN PYTHON STARTUP CODE: ------------------------------------------------------------ Traceback (most recent call last): File "/usr/lib/enigma2/python/mytest.py", line 591, in <module> runScreenTest() File "/usr/lib/enigma2/python/mytest.py", line 485, in runScreenTest runNextScreen(session, screensToRun) File "/usr/lib/enigma2/python/mytest.py", line 479, in runNextScreen session.openWithCallback(boundFunction(runNextScreen, session, screensToRun[1:]), screen, *args) File "/usr/lib/enigma2/python/mytest.py", line 302, in openWithCallback dlg = self.open(screen, *arguments, **kwargs) File "/usr/lib/enigma2/python/mytest.py", line 315, in open self.execBegin() File "/usr/lib/enigma2/python/mytest.py", line 213, in execBegin self.summary = self.instantiateSummaryDialog(summary, c) File "/usr/lib/enigma2/python/mytest.py", line 254, in instantiateSummaryDialog return self.doInstantiateDialog(screen, arguments, kwargs, self.summary_desktop) File "/usr/lib/enigma2/python/mytest.py", line 278, in doInstantiateDialog dlg.applySkin() File "/usr/lib/enigma2/python/Components/GUISkin.py", line 112, in applySkin self.createGUIScreen(self.instance, self.desktop) File "/usr/lib/enigma2/python/Components/GUISkin.py", line 21, in createGUIScreen if not val.applySkin(desktop, self): File "/usr/lib/enigma2/python/Components/GUIComponent.py", line 39, in applySkin skin.applyAllAttributes(self.instance, desktop, self.skinAttributes, parent.scale) File "/usr/lib/enigma2/python/skin.py", line 308, in applyAllAttributes applySingleAttribute(guiObject, desktop, attrib, value, scale) File "/usr/lib/enigma2/python/skin.py", line 208, in applySingleAttribute ptr = loadPixmap(value, desktop) # this should already have been filename-resolved. File "/usr/lib/enigma2/python/skin.py", line 176, in loadPixmap raise SkinError("pixmap file %s not found!" % (path)) SkinError: {skin.xml}: pixmap file /usr/share/enigma2/vfd_icons/vfd_icon_rec.png not found! ------------------------------------------------------------ (exit code 5) getResolvedKey config.plugins.crashlogautosubmit.sendAnonCrashlog failed !! (Typo??) resolve: resolve ${sysconfdir}/enigma2/settings resolve: -> /etc/enigma2/settings getResolvedKey config.plugins.crashlogautosubmit.addNetwork failed !! (Typo??) resolve: resolve ${sysconfdir}/enigma2/settings resolve: -> /etc/enigma2/settings getResolvedKey config.plugins.crashlogautosubmit.addWlan failed !! (Typo??) resolve: resolve ${sysconfdir}/enigma2/settings resolve: -> /etc/enigma2/settings
Uhm... sembra che ti manchi qualche file ... prova a cancellare via FTP il file /etc/skin_user.xml (o magari rinominalo invece di cancellarlo).
