Request Help for flashing image BlackHole-2.0.7-bm750_usb
olindo
Previously I had a dreambox 800 HD,but I have today purchased a Vu+Duo which
had image of the factory.
Have download from here,BlackHole-2.0.7-bm750_usb.
According to instructions that I read in this forum, first make format a usb (fat 32)
Have extract the winrar file BlackHole-2.0.7-bm750_usb.zip in usb flash.
The folder named vuplus, and within its the folder duo that have 3 file:
boot_cfe_auto.jffs2
kernel_cfe_auto
root_cfe_auto.jffs2
First I inserted the usb in front of receiver.
After off the receiver.
On the receiver.
After 2 min. flashing, read in front "remove the usb" and "reboot" the receiver.
I removed the usb from receiver.
Turn off/on the current of receiver.
Now writes in front "Starting..." but not open images, appearance is black.
Where is the problem...?
For DM 800HD any image needed update the second stage ssl 80, 82, 84, 84b etc...
Maybe, there is the same problem with Vu+ Duo...?
I purchased the Vu+ Duo from a satellite shop as original (300euro) in Athens.
How to know that my receiver are not clone...?
Is possibly this the problem is that this my Vu+ Duo is not original...?
boot_cfe_auto.jffs2
kernel_cfe_auto
root_cfe_auto.jffs2
On the receiver.
Have you updated your CFE bootloader? Take a look to http://www.vuplus-community.net/board/threads/vu-duo-boot-loader-updgrade.3555/
aha, I updated CFE bootloade and installed the BlackHole-2.0.7-bm750_usb that download here.
work ok.
I can say now that my Vu+ Duo is original...?
work ok.
You have flashed official CFE and latest BH image.... these two conditions are successfull only on original boxes.
