help HDMI CEC e FUN CONTROL 2
gaghero
to switch off with decoder and TV, not to remain on the decoder and TV after power failure, how are you set the plugin HDMI-CEC ??
P.S. I can not install Fancontrol 2, although I find it in the panel, some help, thanks
About CEC, you should look for a plugin called startuptostandby or similar
About Fan Control 2 IT'S NOT A PLUGIN DEVELOPED FOR VU+ BOXES ... SO WHY USE IT? USE INSTEAD ManualFanControl installed by default into all Vu+ images (original, BH and probably also OBH) to manage fan.
