Help How to install Black Hole on a new VU+duo
wizard725
Hi, I am new to this forum, so thanks for any help in advancve.
I had a TM800 (not gd) and to flash it was easy.
My question is how do i flash blackhole on a brand new VU+duo.
I am confused about flash and usb how do i put 1.7.5 on without buggring my box?
Pls help?
(Hope this is the right place to post such a question).
Everything is already written on the forum.
But agn
If you have an older image in your box before okt 2011
update first bootloader
Be careful you can only use the bootloader for VU+Duo
No mistakes here
Otherwise you will have broken box.
Read this and
http://www2.vuplus.com/image-release/108-how-to-update-vu-duo-cfe
If you have a newer image in your box then you do not have to update bootloader .
1.Download BH image.
2.Format USB stick on your PC format FAT32
3.Unzip BH image and Copy everything on the USB
3.Flash BOX standard procedure with USB stick connected
switch box ON.
4.When it is finished switch box OFF
Unplug your USB stick and switch box ON
Thats funny, i dowloaded a plugin if you get me! and there is no .cfg in USR/bin. I used all the software form the links you gave and installed BH1.7.5
Casn someone PM me what i have missed pls.
You are breaking the rules, You have been warned!
Do not PM me,,,,:furious:!
Another post, in the same way,,the Admin may ban you!
hi friends I have tried to load the new image as i aways have but somehow no matter how itry it wont load could i have damaged the box in any way thaks
Check your USB and make erase format, then extract files into it, and make sure to download the image file from the forum here!
