Help mounting sdd vu solo 2
scubidoo
Hi all
I try to mount sdd on my vu solo2.
I use blackhole 2.1.7 but wen i try in setup initialize the sdd the box crash.
Any way to try to mount on console
Thanks all for help
I would format the disk in a pc in ext4 format. Then plug in the box and indicate the mountpoint. Is the ssd inside the box or external drive??
Then..sorry...I don't know comands, but I saw in the forum once...don't know if it works with internal 'ssd' disk with box power on.
