help need for turner config
keith Martin
could someone please help me, i have just flashed my vu+solo box to blackhole 3.0.2 and i cant seem to see any channels. ive gone through the setup and scanned for channels and found 262 but cant watch them? it keeps saying check turner config. what is the correct turner config for 28.2??
If you only have one dish, pointed at Astra 2, 28.2E, then go into the menu, Setup, Service Searching, Tuner Configuration.
Set Configuration Mode to Simple,
Mode to Single
Satellite to Astra 2 28.2E
Send Diseqc No
thanks for that, just a couple more things if thats ok? do i still put the ccam file into var/etc? also i used to use dreambox edit with cateyesettins 28.2 east file to sort out the channels which doesnt seem to be working anymore. is there something eles i can use because the stations are just one big list? also if you can do you know i can intall Kodi as a plugin and where i would find the file for that? sorry for all the hassle but i was just so used to the origanal setup
Please read the forum rules:
4) Discussions regarding, pedophilia, pornography, piracy (k e y s, emulators, card sharing,
softcams, serial, crack warez) and to any debate illegal under existing laws are not allowed.
Recall also that it is illegal to reproduce your subscription to any Sky decoder IC that
has not paid the royaltes to NDS Group plc.
In order to prevent any discussion about the possible unlawful use of the receivers, it's forbidden
any debate about the smartcard reading and encoding systems.
Dreamboxedit should still work you just need to locate the receivers IP address, in the menu, network, and set up some Bouquets, (Favourites), to sort your channel list out, once done save it, using dreamboxedit, for any future upgrades.
**** W A R N I N G ****
There´s no space for discussion about emulators in this board. Read quickly our board rules, that you should have read, at the time of accession to our forum.
Rules --> http://www.vuplus-community.net/rules.html
