Help need in youtube plus plugin.
mysat-bs
I recently try to use the youtube plus plugin to watch some youtube materials. I have some difficulties to use it, please help.
1. I try to use the plugin to search some youtube materials (which I know them in the internet), but the plugin cannot find those materials. How can I do it? Is there any setting which I should to configure?
2. How can I imput the youtube link to the plugn, if I know the exactly youtube link, such as htttp://youtube.com/xyxyxyx1123 in a standard format?
3. Do we have another better way to watch youtube from the VU+ BH system, if the plugin has limitation?
did you try TSmedia youtube if not try it and you can enter your link in many way ,also it is able to play vevo and most of other blocked videos
Thanks @mfaraj for your information. I have tried the youtube in the TSmedia and it is very nice and do a good search and good play. My youtube issues have been resolved by using TSmadia. Thanks for the TSMedia plugin creators, it is an excellent plugin.
