Help needed! Best skin for "whats on today"?
newtothisvu
Hello,
I'm completely new to the world of motorised satellite but just had a system installed this week. I have all the usual stuff added but would really like advice on what I need to add to get a better list of what's on please. I can see now/ next on some channels but only after accessing one first and would like a more comprehensive way of looking to see what to watch. Does a skin (I think that's what I need) exist?
Any other hints and tips would be great. My box is a VU+ Solo.
Cheers!
Dec
Hello,
Cheers!
Dec
The EPG plugin is a solution for you (only if provider has it, most of them yes). Try to search on forum for an informations.
HD Glass16 skin will show you current and next event in channel list without having to actually switch to each channel.
CoolTVguide will show you more - it's a full featured EPG. I use both.
I use MX red diamond for BH ver. 2 and above can recommend this which is available from BH server. But as above only shows now/next. You can also use multi EPG by pressing 3 whilst in channel list this is embedded in the BH image so no need to download anything. This graphical EPG can also be accessed by long press on blue button and selecting from list. Hope this helps mate :-)
