Help Needed !?!?!?!?
fugees48
Hi All,
My VU+ Duo box is not responding straight away. All buttons will respond once and when you press again they will not respond unless you press a different button before pressing them again
For example, when I am zapping thorough channels the button will only respond once and I have to press the volume button once before I can zap through another channel.
But If I continue to press the same button it will skip 2 or 3 channels before it stops again.
Can anyone help me on this please?
Kind Regards
Hi All,
Kind Regards
Check remote control batteries.
