Help please on BlackHole image
benaknoun
Hi Guys
I need some help please.
Installed latest image of BlackHole on my VU+ solo SE.
The problem is, the text on the menu is too small, and from my sofa i can't see it properly and it gives me a headache.
Is there a way to make this text bigger?
Also, on BlackHole, will i be able to see the strentgh of the signal of each satellite before scanning the channels?
Thanks in advance
Hi Guys
Thanks in advance
Try to select a different skin from Bh addon.
Hi Guys
Thanks in advance
You can give a try .. to install and configure fontmagnifier v.061 ... install it from addons server!
