i need a stable image for my VU+ SOLO
i'm using blackhole image 1.4.2 it restard alone ( inadyn is disconnecting all time)
Are you sure inadyn settings are ok?I did 60 sec but
the problem continues
Did you give setting through RC or writing in the file inadyn_script.sh with an editor?yes I am sure
Can you connect with telnet and give this command and tell me what answer you have?I gave the command to the RC.
/bin/sh: /usr/bin/inadyn_script.sh: not faund
this message has arrived
Vuplus 2.0.7 + BlackHole 1.6.5 bm750
bm750 login: root
Password:
root@bm750:~# /usr/bin/inadyn_script.sh restart
-sh: /usr/bin/inadyn_script.sh: not found
Try to give 755 permissions to file /usr/bin/inadyn_script.sh if it losts them.Vuplus 2.0.7 + BlackHole 1.6.5 bm750
bm750 login: root
Password:
