Help: problem on the Led of my vuuno
forzajuve
Hi all,
I just installed the version 1.7.1, i noticied a weired thing: the led of my vuuno doesn't display the name of the Channel where i am but it displays "vu uno" or "black hole".
Is there any thing i CAN do to fix this? Any suggestion Will be so much appreciated.
Thanks in advance.
You have restart image after instalation
and you have disconnect USB stick from BOX ??
You can better use BH 1.7.2 image
