Help | Red Light With Hang A Starting
iahmed009i
hallo every one
from tow day i update my uno l HD from the menu and hang my receiver so i tired to install a new image but not read the usb
plz help urgently,,,
Matrix10
hallo every one
Problem with flash image has been written many times here.
You have to try more USB sticks.
Not just one.
And you have to be sure you're doing everything right, to flash box.
If it does not help you may have a defect box.
cerejo
*** DOIS AO ESPAÇO FLASH LIMITADO, RECOMENDAMOS QUE ESTA IMAGEM SÓ SEJA USADA EM OMB (OpenMultiboot) COM ESTE MODELO ***
ONE - DUO e DUO2 - SOMENTE e SOLO2 e SOMENTE SE - ÚLTIMO
Caneta USB formatada em FAT 32.
WINRAR - ZIP DE 7 - WINZIP
Imagem zip descompactada. Exemplo: BH 309 e mude para USB apenas ou arquivo vuplus
