help subtitles iptvplayer
hello
theres any way to increase subtitles on iptvplayer?
thanks
Yes ... do this:
Open IPTVPlayer plugin:
Drop down on the icons until you found the GEAR ( configuration ).
Open it ... drop down on the list and select:
  • External movie player config.
I´ve setted mine with 60 ( font size ) and 64 ( heigh ) ... changed 4 for 0 on line spacing ...
I use IPTV mediaplayer for play my mediafiles. Work fine but only problem, when i want play same file second time subtitles going wrong. I find that mediaplayer put in MovieMetaData dirctor ovn .iptv fail and for normal subtitles i mast delete this. Is this normal or something wrong in my settings?
