Help to copy my full backup file..
jity
I have vuplus duo2 but sadly it's broke now with white led :(
I get new vuplus solo and I only have fullback up in my usb.. How can I transfer my channels and my plug-ins and all the stuff?
I tried to use multiboot but it's gives me error :(
If you have backup from duo2 and you now can run he on solo he no will be work on solo.
If you can create backup solo and copy to computer is very easy.
Made this by ftp and copy to computer
The VU+ Solo is one of the oldest VU+ receivers, replaced by different models, the VU+ Solo SE, the VU+ Solo SE v2, the VU+ Solo2, and the newer VU+ Solo 4K, can you please confirm which model you have.
You can try accessing your damaged VU+ Duo2, using dreamboxedit, to back up your Duo2 channel list, and Bouquets, but it might not be possibe.
The Duo2 might be easy, and cheap, to repair, by replacing anydamaged capacitors, if you don't feel confident yourself check if you have a local shop, I have a local telecentre, who is very reasonable, and will even get me parts, for some electrical goods, that are classed as trade only.
It's sol
its solo SE with 2 tuners .. Yes I only need to copy channels list that's all.
My duo 2 stuck with white led for 3 months I can't even find motherboard and I give up.
I saved etc/engina2 file from my old duo2 !
Now when I replace it in my solo se and reboot it's crashed !
Can u tell me what the files make my solo crashed ?
Thanks for help ..
