Help to recognize/activate VU+ Dual Band Wireless USB Adapter
Ok, i will try and post a video.
Just FYI: i have made the update by Lan cable, i always use DHCP, i have 2 SSID one for 2.4 and one for 5GHz (tried both without succes), never have to change the Gateway or DNS (i'm using default provider DNS without any problem)
I will keep the thing updated
Cheers
I have gived up... have found and bought 3 CPL powerlines Netgear 1000Mbps for 35€ on second hand, the speed is very weak (worst then wifi) as my electrical power grid is "strange" and not build with powerlines in mind (1957 house)
Not happy :(( but i can use my stb
I'm watching this thread, maybe one day the sun will shine :))
hi
I have uno 4k se
I have two dongles.
TP-LINK TL-WN722N Ver2 and
D-LINK Wireless N 150 Pico USB Adapter N 150
The device does not recognize any of them.
Does anyone have a driver?
And in what direction should I transfer driver.
Thanks.
hi
I have uno 4k se
I have two dongles.
Thanks.
Off Topic :offtopic:... This thread is only for VU+ Dual band wireless usb device. and not for other devices even if they use the same drivers. ;)
