help with blackhole image
lewis65
Hi,i have just got my vu+duo which had the blackhole image already installed.I have had a lot of problems trying to install a hdd to it.I have been told that i should install the hdd before any image was loaded.So now i need to take off the black hole image and then install it again after the hdd has been fitted.Is there any way i can save the black hole image, if so how?.Then how do i put it back onto my duo.Any help would be useful thanks.
That's not true.
Start image.
Enter in telnet and type command:
mount /dev/sda1 /media/hdd
when the disk is mounted goto menu -> setup -> hard disk and inizialize it.
If you don't see hard disk in the menu enter in telnet again and type the command
Blackholecmd re2
After the hdd is succesfully inizialized you can set it in Black Hole devices panel
blu->blu->devices manager
What is the size of HDD U'r going to install?
Hi,when i powered down the vu+ and connect the 2 leads inside the box.When i power up again the box does not respond in anyway it just says vu+ duo on the screen.If i power down take off the 2 leads apply power the box works ok.I did get it second hand it's a samsung 1tb if that helps,thanks
