help with channels black screen
Lordgothic
hi everybody! i put this thread here, i dont know if this thread go here or in other subforum in this case sorry and traslate to the right position!
i have 2 channels with black screen, this ones:
Monitor Games 11919 V 27500 3/4 at 9.0 east
EFB 111303 H 30000 2/3 at 16.0 east
i have the correct "info" for see, but blackscreen, only can see by stream with vlc
any solution? any help?
thanks in advanced!
Both those channels appear to be BISS encrypted, please read the forum rules, before asking any further questions, on this subject:
4) Discussions regarding, pedophilia, pornography, piracy (keys, emulators, card sharing,
softcams, serial, crack warez) and to any debate illegal under existing laws are not allowed.
Recall also that it is illegal to reproduce your subscription to any Sky decoder IC that
has not paid the royaltes to NDS Group plc.
In order to prevent any discussion about the possible unlawful use of the receivers, it's forbidden
any debate about the smartcard reading and encoding systems.
im not talking about encrypted systems...
im talking about drivers... that channels are blackscreen not for encrypted keys, those channels are blackscreen for the drivers or something that i dont know
they only can watch with stream at vlc
i dont talk here about biss encrypted and not put here nothing about.... only need a solution for see those channels in norlmal way not like a stream
The only thing, I can think of, at the moment, that VLC player can open, and most receivers can't are 4:2:2 feeds, once set up.
I'll try scanning in your channels.
Evrofutboll Gonki 1, 16E 11303 H 30000 DVB-S2 8PSK 2/3 and
Monitor Games, 9E, 11919 V 27500 DVB-S, and report back, but lyngsat has both listed as MPEG-4 BISS, although they are quite often outdated.
Just checked and neither of those channels, are opening for me, although others, on the same transponder, are, which probably means that either they are encrypted, or experiencing difficulty.
If you have a different satellite receiver, or know others with different receivers, have them check the two channels.
hi mick12334 thanks for your words...
yes that channels only can open stream with vlc player.... and im searching solution for see normaly
with different box/receiver runs normaly, i checked with engel 8100 and runs fine. but with vu+ solo 4k only with vlc player and for this reason put here this thread...
I do not know why those channels are not seen, I do not know if it's a driver issue or something else
its something internal at vu+ that cant open normaly like other satellite receivers...
thanks a lot for your words.... really apreciate...
i think thats a internal problem that only vu+ factory can resolve... or one specialist man!
I have the same issue on vu+ zero4k and this .ts can not be play on zero4k but play on edision osnino , two months ago had the same issue on osnino, now with new drivers play
it's possible to fix it ?
hi again... 2 months later... still waiting one vu+ driver update to see some channels with black screen that only can see via vlc/pc stream....
thanks in advanced!
*** WARNING ***
As @Mick12334 said above, the channel Opap TV monitor games is encrypted, nothing to do with it.
According our board rules ( §4 ), is not allowed to talk on our board, about any kind of illegal stuff.
The discussion, will stop here:
*** TRHEAD CLOSED ***
