Help with lcd4config file
Ruudi
Is there any ready to install lcd4config file for channels picons on the LED screen? Duo2, fw 3.0.9.C
??? What do you want to install?
The only thing you need to do is set the L4L picon section to read it from the device you decided for them.
I try to restore former lcd look. Only three things on the led: program picon (logo) + time (clock) + program progress bar. Nothing more!
For old fw 2.1.7 was a lcd4config file which gave simply this lcd4 look. Help is welcome!
Self answering: Sorry, forget the problem! It's ok now.
