Help with open vpn please.
calmnowisthis
Hi there, I am trying to get Openvpn working on my VU+ duo 2.
I am using hide.me VPN paid service. I got on to support telling them what I was trying to set up, and they sent me the following files:
"Netherlands.ovpn"
"TrustedRoot.pem"
I tried a few settings but can not get it working.
If any one can help me get it going I will be very grateful.
Thanks.
All working now. The only problem I am having now is that after every reboot I have to telnet in and reinstall tun.
Is there a way to make tun persistent ?
Thanks for any more help.
I did a reinstall (problems with setup) and I copied my Openvpn directory over before I re flashed.
I ftp my copied Openvpn folder over to my fresh install, and now Openvpn no longer works.
When I check my IP with telnet command it shows my ISP. Also, I saw a log message reading "Address already in use"
Thanks for any more help with this.
All sorted now. I had to go to an active TV channel in order to obtain the correct time. I tried connection with OpenVPN and it is now showing my VPN providers IP address.
