Help with OpenVPN
smcmullan88
Hi folks,
Sorry for the long post. I have been setting up an old DM800HD clone receiver with a blackhole image. I managed to get OpenVPN working however it doesn't activate automatically. When I go to the menu and openvpn and hit activate i get the message "you have to activate openvpn before to start".
So next I tellnet to my box and run /etc/init.d/openvpn start - it says client failed > password serverp2p however if I then go back into my OpenVPN menu it says running. So I do a grep "IP address is" on the box and it shows up with the IP for Amsterdam - yes my VPN has connected. This is brilliant only downside is I have to do this everytime i reboot the box. Would love to know if there is a way to get this to do this from startup.
Thanks
