Help with subs on channels
solvufree
I got the first problem, i use the newest BH img and there is not a plugin to get a sub in channels.
And how to uninstall a ipk files, i can`t uninstall it in meny, can i use the Telnet to remowe it????
About subs plugin you can look into this Board -> Vu+ Plugins
About ipk removal you should use telnet command.
Ok, i have try this plugin Subtitle player by DD but there is not Norwegian subs there.
And what is the command in Telnet to uninstall then???
About which subtitle we are talking about.
We have a TV channel DVB subtitles
and TXT subtitles.
If the channel have one of those subtitles
Then they you activate with
Subtitle Selection button on your remote
or Audio button>> yellow (menu)
DD Subtitle player is movie subtitle player.
You can remove ipk installed files with telnet command
ipkg remove enigma2-plugin??? name.
Plugin/Package name you can find in /usr/lib/opkg/status (file)
Ok, and i talk about TV channel DVB subtitles, i have a plugin on my 7025 and 8000 and that name is 2SUB and that work good.
There is not a same to VU+ then????
Plugin you do not need,
DVB subtitles It is already within the image.
agn
