Help
daif01
I try to install the T90 on the roof for the following positions wse 0.8, 3.1 east, 7 East, 13 East, 19 East, 28 East, 36 East and 42 East. all lnb is MTI highline lnb except at 36 degrees which is circular. I have Axing SPU 81-00 Diseqc. I have tried the following two sets:
lnb1----->diseqc1.1------>AA Uncommited input 1
lnb2----->diseqc1.1------>AB Uncommited input 1
lnb3----->diseqc1.1------>BA Uncommited input 1
lnb4----->diseqc1.1------>BB Uncommited input 1
lnb5----->diseqc1.1------>AA Uncommited input 2
lnb6----->diseqc1.1------>AB Uncommited input 2
lnb7----->diseqc1.1------>BA Uncommited input 2
lnb8----->diseqc1.1------>BB Uncommited input 2
And:
lnb1----->Uncommited input 1
lnb2----->Uncommited input 2
lnb3----->Uncommited input 3
lnb4----->Uncommited input 4
lnb5----->Uncommited input 5
lnb6----->Uncommited input 6
lnb7----->Uncommited input 7
lnb8----->Uncommited input 8
I've tried blackhole, open pli and VTI, however I only get signal from 19 East and the weak signal from the 13 th, when I search 28e, I only show transponder belonging to 19 CE
Can a Diseqc 8x1 (Axing SPU 81-00 Diseqc) control 8 lnb? I do not understand why I when I search 28e, I only show transponder belonging to 19 th?
from left to right 0.8 west, 3.1 east, 7 East, 13 East, 19 East, 28 East, 36 East and 42 East. All angles and calculations according satlex.Dock I just get the signal from the 19 east and the weak signal from the 13 east, when I search 28e, I only show transponder belonging to 19 east
