I have black hole image 1.6.2. How can make the remote control like that when i press number 2 one time for example i would get the channels that began with A, and when i press number 2 twicw i would get the channels that begans with B.
Thanks in advance
Yes it workwd .Thank you very much mate.
Blue button>>Red>>Red>>Enable Epg Buttons in Channel list>>NO>>Red (Save)try this
You are welcomeYes it workwd .Thank you very much mate.
This forum is great. you get help for your problem in 4 minutes.Thank you.
