Help
daif01
Ihave Vu+duo blackhole 1.6.6 image.I have Vonet VAP11G.How can i install Wifibridge Vonet VAP11G to get wireless internet connection.
Tanks in advance
You need to configure the device on a pc then plug the ethernet cable into the port on the rear of the VU and plug the power supply of your device in to a socket.
To make life easier make sure you configure the VU network to DHCP for the initial set up.
