I have vu+duo, blackhole image.I have vonets VAP 11G. I have installed it on my pc. i got green light.i have connected my wifi bridge to my vu+duo and got green light .but i cant find the option scan wireless network under network setup option. Do i have to add some driver or some thing like that?
thanks in advance
thanks in advance
thanks in advance
The wifi bridge is an ETHERNET adapter! You must configure it via PC to accomplish to your wifi network and then connect to box into ethernet port (and USB for electrical part).
Thank you for your reply. i have configure it via PC and then connected it tothe box inoto ethernet port and USB. i got green led on wifi bridge . but on network setting LAN ok,local network ok,DHCP ok, but IP adress not ok and namnserver not ok. i have downloaded the plug in wireless lan network but i cant see it on plug in list.Any suggession is appreciated.
You don't have to use wireless setup because the box is connected via ethernet. This mean that the box have to work in lan mode and not in wlan mode.
So you have
1) configure your bridge via Pc
2) configure the lan network adapter in your box.
So you have
nk you for your reply .I have done all this steps and i got flickering blue and orange light on the VAG 11G.when i connect it to my vu+duo i got flickering blue and orange light on the VAG 11G but the vuduo tell me that network connection is nt ok.
Hi daif,
after you have configured your bridge you have to goto:
main menu -> setup -> system -> network -> lan connection -> adapter settings -> User Interface = yes Use DHCP = yes
If your network is not yet working after these steps it means that your bridge is not well configured or is not working.
I suggest to buy a Vu+ wifi adapter
