Help
daif01
I have duo +vu blackhole 1.6.6. is it possible to record analog or cable tv channels that i get it via my cable provider.before couple of years when i had my old VCR i was able to connct my cable to my VCR and connect the VCR to my TV and then set timer to VCR and record analog and cable tv via VCR.Is such function possible via vu+duo.Thanks in advance.Any suggessions is appreciated.
If you mean DVB-C recording, you need a USB DVB-C device prior to record on internal HDD unit of your Duo.
