I have vu+duo, BlackHole 1.7.1 server tuner image,3lnb(4.8E,13E,0.8W) connected to tuner A via disqc.Tuner B is loop through. everything was the last 10 months.The problem is, the lase 3 weeks some channels on hotbird sometimes suddenly the signal decrease and then no signal for 10-20 minutes and then appears again, the numbers of channels with this problem is about 30 channels, other channels on the same transponder, same polarity works fine.this problem happens only with Hotbird.No problem with channels on 4.8E or 0.8E. I checked lnb and disqc, cables , everything semms ok.I tested another image but same problem.I dont have another receiver to test it.
Does any one have same problem?
Any suggession is appreciated.
thanks in advance.
thanks in advance.
