press ok in "dreambox edit"?
i pressed ok and save channel list in directory back up , send new list in "FTP".
but why old list channel back in reciver?
1. Load in "DreamboxEdit" settings list which You want to edit something
2. After finished editing press "SAVE"
3. Press "FTP"
4. check "Auto E2 reload"
5. Send list in Your box
dont work!!!!!
old list channel is back!!!
i am searching manual search for finding channel, after find edit channel in "dreambox edit" and send list to reciver.
why adding old channel in new list after restart and select in new list channel?
notic : new channel added is same frequency`s channel in new list
This must working but in some reason gui need to be restarted to apply edited list.
For me on VU+DUO when I check in "Auto reload E2" I do not need to restart GUI.
Please use dreambox edit version 4.0 and inform us with result , we want to know which is resulted from that version or this is internal bug of BH
and if you have more time please check it in last issue of B.H such as 1.6
use DreamBoxEdit_4.0.1.2 & DreamBoxEdit_4.0.0.0 in blackhole image 1.6.2 Final.
but back old channel list after select channel in new list on GUI !!!!
this problem is setting or bug of blackhole image 1.6.2.
I realy don't know what You do...I had not any time problem with it.
If You change just 1 channel You could make manual scan (wit RC ) for that frequency. After delete old channel and go to new channel (in section "all channels" or one satellite) and put that channel where You want ( RC,press menu/put in bouqets)
Also You could record short video about Your problem and put here because I am sure that You wrong somewhere.
