Hi y'all, need some help please
U54
Just rebooted Vu+ Duo after SGTFlipFlop update and "nada".
Boot up soooo slow and " starting enigma 2" just remains.
No reception at all. Checked back to tuner config and showing "nothing connected" on both A & B.
I don't seem to be able to tune either whatever I do.
I know the lnb and cables are good because I've checked with another box.
Any suggestions will be much appreciated.
Do you have a backup of your old satellite.xml ?
If not did you use personal backup ? Try a restore from this if you used it.
Hi U54....what you mean by SGTFlipFlop....and "nada"......:confused:?!?
However I think the Image @USB, after extracting, may be corrupted!
Re-do another un-zip directly to USB( I would recommend to make a quick format to the USB stick, before un-zipping the files to it).
Thanks Artorius & a911.
I reinstalled using Vu Perfect zip to usb. All ok now.
Thanks again.
